Hi,
The front wheel is 50mm and the rear wheels are 65mm. The retract mechanism you have appears to be the same as CARF sells for the Rebel Hot.
Originally Posted by
Airforce7
Interested in possibly purchasing one of these and I have a complete set of JP Retracts and controller from another plane and I'd like to check and see if they would drop in to this airframe. Need some help from you guys to let me know what the size of the JP retracts are that came with your kit. Here's a link to what I think will fit in this jet, includes dimensions on the web page...
JP Hobby Alloy Electric Retracts Set (3 retracts) with Brake wheel For 7-8KG turbo jet Plane for rc models wholesale from Hobby China Shop. Can someone do a quick check to see if these dimensions match what you have?
Also, the main photo on CARFs
website is a little misleading because they show bigger diameter tires than what they offer for spares. My set has 65mm diameter wheels for the mains and a 50mm for the nose. Is that consistent with what you guys received?
