Hi guys.
Maiden done. Balance as mentioned in my previous post is very good starting point. at beginning of flight slightly nose heavy but after few minutes its ok. Flies very well with a 120 turbine, very agile and good scale vertical performance.
David is right about softness of landing gear, for some reason turbine flamed out in final and landed short of runway on rough grass and lower leg part of struts bent. part of reason is probably stifness of the struts springs.
Regards
Eduardo
