Originally Posted by
Big Sky
OK, Next problem I'm having, NO Steering, Using Aux 5 on receiver for steer in to the lg15, mixed to rudder in transmitter. If I pull the steer in lead out of the receiver and plug the steering servo straight into the receiver all works fine, so I know its receiving a signal to steer. But running from aux 5 to steer in on controller, then hook servo to steer out on controller, it don't work, so I know the transmitter is sending steer command to controller, but the controller is not sending steer command out. I zeroed out all the gyro setting in controller to see if that was set up wrong, but still cant get the steering to work when using LG15, only works when steering servo is connected direct to aux 5 on receiver. Any Idea's ?
‘I know why...I have encounter that before.......the LG15 stop the steering with the gear up...and right now it knows the gear is UP, do a relearn...
Yes your switch is down and the gear is down...but the controller is up
a quick test switch the gear up and try the steering....
