Originally Posted by
jvaliensi
I have a LGC-13. It was working okay but the gear was down and the controller said they are up. So I started to try and change settings. I'm using the screen form my X45. Not it don't work.
Is there a way to reset it to factory settings? I cannot figure out how to scroll thru the menu and change things. Its not user friendly. Why cannot it be plugged in to a computer? Is there a better controller?
I'd switch to the JP controller I have but then I have to redo all the wire ends.
You could make short adapters until you get the LGC 13 is sorted out
