Originally Posted by
Big Sky
Still no steer, went through everything, got switch set up for the position I want for gear up and gear down, which matches the controller when it shows gear up and gear down. no steering in either position. receiver is sending out the steer command to controller. tried different servo to be sure and still cant get a steer command out of controller. Now what?
Not sure what to say...it’s not that complicated.....take photo of you setup, I’m sure it’s easy to fix, and yes reading the manual with the controller and TX make things easier to learn.
