A little hard to follow
I different thing in different jets....what I mean is once setup I don’t change them even if there’s a better way, because I never loss a single RX in flight...so I’m not too worry...but I do try to set them up with the trend
My trend setter is F1 Rocket
I also set my model so they can flow easily without the CP, meaning normal control and enough Expo so it’s not all over the place....but also not mushy when the Gyro is ON.....normally just one mode (normal) unless it’s a vector Jets that could hover the 2 mode (normal again but different gain)
What I do is Number 1 RX goes into the CP(B) then RX 1 of the CB....
Number 2 RX into RX 2 of the CB (could be a 2.4 or 900 depending on the model)
In some model I do Number 3 RX into the EXT port of the CB (set to receiver)
I also do extra power into the CP from the CB servo port
