Originally Posted by
nomorelogin
Hi guys!
Several days ago I've finished conversion of my P-47D to electric version.
The setup is:
Dualsky ECO 4130C-V2 470kV
HobbyWing Platinum 80A ESC
APC 16x8E
Zippy Compact 6S 4000mAh 60C
She flies very well (yet she is little tail-heavy). But the battery a little bit bigger than needed (in terms of linear dimensions - 149x44x54mm) so it's a bit tricky to fit it in.
Anybody with electric versions, what brand/model of battery do you use?
Can't post maiden flight video due to forum's limitations.
Here is a good solution for the battery location to get it to balance without adding weight:
