Originally Posted by
whewth
Thanks Daniel for the quick response. Appreciated your assistance. I'm curious what's your CG for this jet? How is the inverted flight with that CG?
The T1 Mini will fly well balanced at the center of the carbon wing tube. Slight down elevator pressure to fly inverted. You will note the T1 Mini does not have a symmetrical airfoil. Consider adding safety tie wire to all your fuel fittings to prevent leaks.
Randy
