Originally Posted by
seaside535
I have been flying this bird with the recommended CG. I’m using the Igyro 3e. The gyro was recommended to me by Dirk to help with the nose dropping. I. Have a replacement nose retract on its way so she will be back in the air. If it doesn’t fly the way I want her to I might sell her.
Personally, I would not use a gyro to address this issue, but I suppose anything is possible. I have seen gyros used to address nose drop in KE flight instead of holding rudder, but only for the maneuver. Typically by turning-on a flight mode with HH enabled on the rudder. This flight mode would not be used for basic flight. I hope you don't mind me asking a couple questions related to the gyro setup. I assume you have it set on a 3-position switch? What is the rate % for each of the three positions? This being an F16, are you using elevons in your setup?
