RCU Forums - View Single Post - Smart Fly POWERSYSTEM EQ6
Old 11-28-2020 | 07:35 PM
rcplanenut
My Feedback: (12)
Default Smart Fly POWERSYSTEM EQ6
Used Smart Fly POWERSYSTEM EQ6
From the SmartFly website:
The PowerSystem Eq6 combines three Smart-Fly products into one compact, light system. The unit has eight channels, six of which have the Equalizer (servo matching) function built into them. The unit uses Deans Ultra Plug connectors for power and accepts power from two 2-cell Li-ion or Li-poly batteries. The unit has a built in BatShare to protect against one bad battery affecting the other battery. Power for the receiver is brought straight from the battery connector to a filter and regulator that supplies clean 5.0V power to the receiver. The servo regulator is adjustable from 5.5V to 6.5V and is connected by a large power bus to the servo output connectors resulting in no voltage drop due to wiring or connector resistance. The standard version is designed for 85cc to 120cc size planes and the regulator can supply 7.5 amps of continuous current with 15 amp peaks.
For up to 100cc (IMAC 3D) / 120cc (IMAC only) / 25lb Scale gas aircraft or jets
Light weight, 4.4oz, 128g and compact, 6.0" x 3.0" design
For Li-ion or Li-poly batteries
Battery inputs protected against battery faults, lost cell or short
Adjustable servo regulator, 5.5V-6.5V, 17.5amps continuous, 40 amps peak
6 of the 8 channels have servo matching and reversing
Filtered and regulated 5.0V power to receiver
Receivers can be end-loading or top-loading
Fully buffered and RF filtered signal line for each servo
Long servo lead line matching
rcplanenut is offline
