Originally Posted by
Tip22v
Carsten,
Thanks for clarification, I was not sure about how it would work without Jeti. No worries on the firmware updater program, once I figured out how to update the firmware it was pretty easy. I think you did a really good job with how the brake functions are organized in the Device Explorer. I have not tried the retract or door sequencer programming yet, but I'm confident it will be as straight forward as the brake settings.
I do have a question for you: in the LGC-15 you can select Heading Hold for Gyro Braking as an option (verses Rate Mode), I have not found a way to do that in the CRU, is this an option with the CRU?
Thanks again- Tom
Thanks Tom,
regarding the gyro, only rate is supported in the firmware.
To be honest, the door sequencer is (almost) the thing I'm most proud of, it shows brilliantly why Jeti in combination with the device explorer (and a device that is supported by the device explorer) is such a fine combination
Regards,
Carsten
