Further progress on the tank - magnets installed. At this point the 10mm N52 rated magnets are so strong that you can pick up the tank from the upper hull and it won't come apart.
You can also see that I switched the connector over to an XT-60 and will be running the tank off a 7AH 18650 Li-Ion battery pack. Also installed a large metal turret ring I had here that will be mated to a metal (fast) rotation unit. Magnets are the countersunk variety so you need to order both north and south versions.
I think I may switch my T34s over to Clark boards so that I can install my Open Panzer TCB in this tank. There is tons of room for the ESCs and the TCB board.
