RCU Forums - View Single Post - JetCat Newbie - help requested
Old 12-11-2020 | 04:38 PM
Andy_J
Originally Posted by mr_matt
hi Andy,
i don't know about manuals, i would not be surprised if there is not one but i don't know for sure.
with multiple turbines you still need one ECU per turbine. the ecus can communicate with one another on startup, as far as i remember that is the only advantage to linking the ecus in a multiple turbine install.
as for the control of the turbine, it is not voltage controlled directly, the input to the ECU is a servo signal.
if you are not using a typical rc receiver, a pulse width modulated servo signal that can be generated with a servo driver. these are little boxes with a knob that lets you move a servo.
Thanks Mr_Matt, that's all really helpful. Sorry for the delay in sending my thanks, I had to do some reading around to ensure I understood your reply and didn't need anything explaining 😀.
