Hope I can get some help
Having a hard time setting up the T-1 mini again. This time my Futaba 14 channel receiver had two ports that were not working so the LG-15 was not recognizing the brake setup. Now I have the brake wire in my DG1 input and it is working now. I had the two channel setup but now when I cycle through all the options it is gone. I see one channel, Futaba S-bus etc but not the two channel option. It is currently set to one channel. All my control surfaces work, retracts, door, and now brakes. What's the difference between the one channel and two channel RC setup? I got the PNP from Dirk. Kinda wishing I saved some money and just built it myself, servos not centered before horns put on and stuff like that. How many mm of down elevator are you guys mixing in with half and full flaps?
Thanks again,
Matthew
Reason: Deleted a question
