Leave the brake off.
The brake is to more quickly slow a heavy prop or if it is in a car that needs braking. The brake will make more heat.
If you can connect an amp meter that is capable of recording a peak to see what your pump pulls while starting up with long lines and fluid in it. That is the number that you ESC needs to handle to survive the sequencer.
