ORIGINAL: zonker123
You don't need to weigh the plane down by adding the elevator or rudder servos. Since all you want to do is hover, just glue the the control surfaces into the proper position. You only need the servos if you are going to try to loop or land.
take care
Z123
I do occasionally like to loop and land. I was therefore going to use those little WES Tec micro servos. You know the ones that weigh about 2 grams, and have 100 grams of pull on them. Or do you think this is overkill?
