Originally Posted by
JSF-TC
You could also just use a Telemetry Control for Status = 9 to trigger the warning.
Health warning - I've not tried this method but I don't see why it wouldn't work
I use the first method I posted as most of my telemetry adaptors are older and do not output the Status message. According to Gaspar they can be updated, so I plan to send mine in.
Paul
Even if you can, I wouldn't do it based on the status code for flame out. There are other reasons such as Low RPM, that can result in the turbine shutting down in flight. Alarming based on something such as pump voltage and EGT, etc should cover them all where the flame out status code would seem to cover only one of the causes.
