Unfortunately, most RC flyers will not know a good answer to that question for a number of reasons.
RC electrical equipment changes often and without pattern. Also, each of us encounters different environments and may or may not be using equipment that is affected.
The good thing is that you appear to have experience with boats. If you're using the same RX/TX/servos in your planes as you used in your boats, you're the best person to answer your own question.
good luck
