RCU Forums - View Single Post - HOTA D6 Dual D6 Pro Smart Charger
Old 01-10-2021 | 02:56 PM
maxjanet
Originally Posted by ticedoff8
The first thing I'd do is read the manual: Attachment 2269069
The second thing I'd do is make sure you are plugging in the balancer leads on the pack and using the charger's LiPo setting for "Balance Function".
If you are using the wrong chemistry, not plugging in the pack's balancer lead or not using a balance charge option, then it is typical (and very bad) that one cell will over-charge and at some point fail. That failure may include bursting into flames while it is being charged.
Hi,
Thanks for your prompt reply with helpful information and the link to the detailed manual. I will now always use the balance charge setting when charging LiPo's .
Regards
Max
