RCU Forums - View Single Post - CARF Joker build thread
Old 01-11-2021 | 08:29 AM
  #864
jvaliensi
Tail Pipe Installatoin.
I've installed the pipe and found that the pipe is not parallel with the turbine mounting plates. It slopes up a degree or two. The cone lies on the factory rest and the top of the pipe is against the fuselage (per the instructions).
The pipe ends at the right spot at the rear of the fuselage.
The carbon inlet cone was screwed to the pre-drilled holes and it went on straight. But it does not push up against the wood formers at the mount. It appears the rear former was not glued in perpendicular to the mounts, which explains some of the offset.
I'm hoping this is all okay.
