RE: Spacewalker 2nd servo mouting for elevator
I mounted two low-profile servos for the elevator under the horizontal stab, with short linkages to the elevator halves. This is done partly to offset the heavier gas engine up front. I don't recommend the servos in the tail if you are using a lighter glow engine, as this plane tends to build tail heavy. I just like dual servos and short linkages better than single servo and long pushrods in general.
