Back to revisit the issues see how this goes with sprockets and metal drive gears mentioned earlier you do it when you can .
see if there is a improvement not mato tracks .
correct gentlemen
now i like the clearence in sprocket and track.
the track guide runs freely which i like .
show soon
really track guide needs to be free running or you get binding have a look inner sprocket no real use first issue also on trsck guide wear even if plastic guide you see binding
outside sprocket perfect
Guide
difference new track the guide horns have more movement
More investigation you find the issue the guide on tamiya is not central .
Right hand track will see left technically the guide it should run free not fixed .
Progress tracks on perfect plumming in bluetooth works a dream just remember you need power stereo amp your set.
sits right in driver hatch for access
I hope you like this.
