RCU Forums - View Single Post - CARF Bolt! Build thread
Old 01-24-2021 | 05:10 AM
  #100
F1 Rocket
Originally Posted by Dave Wilshere
Be interesting to see the pump figures with the pipe runs on the suction side you have. I would monitor them over time once the fuel system settles in.
Dave
Feed lines from the tanks are 8mm, the Digitech UAT has very low restriction, and the 6mm run to the pump is shorter than other setups I’ve done. But David can easily review the pump numbers on the Jeti logs after each flight to confirm all is well.
Can you tell me how much fuel you had in your tanks when you weighed yours?
