RCU Forums - View Single Post - CARF Bolt! Build thread
Old 01-24-2021 | 11:16 AM
  #102
F1 Rocket
Few more things checked off the to do list. One of these was to pull the pipe and shorten it a bit. I think it looks much better now. Once that was done I could install the Jets Munt M250XBL. The mounting holes for this engine end up being almost directly on the edge of the bypass. To get around this issue I installed some M4 blind nuts upside down after first opening up some clearance holes in the bypass. The M250 also has a short nozzle and consequently needs to be slurred pretty far back as well. It’s a tight installation but it worked out quite well.
LA jetguy (01-24-2021)
