Originally Posted by
john comp
Thankyou all that have replied, i errored in the prop size, it was a master airscrew 13-6, and that is recommended by OS, as far as the end view i took that to show the pocket in the molding, but there is no saw cut, sorry if it looks that way. Now as to the paint, i wanted an aluminum look to it. so much for scale.
Thank you. That does make a lot more sense then. Yes, a void or two in the molding. For sure, and it was in a very bad spot as well!
