Sorry to hear that. Did you have flight modes set in your transmitter?
Originally Posted by
jvaliensi
Well my Joker was test flown. The balance was spot on, the elevator did not feel too sensitive. However, my elevator compensation for flaps down was not enough. We had to add loads of down trim to get it set correctly. Ended up with 10mm down with full flaps and 4mm down with takeoff flaps.
Unfortunately, I had a really bad landing and damage the model. I'm too pissed off to fix it. I may pull it apart and use the parts for another model. I put it in the attic while I think about this.
