Originally Posted by
MarkF
Vey nice video CM. I am looking to purchase my first turbine and it will be a Swiwin 190B My friend runs this turbine on kero and recently switched to diesel. He thought it had more power using diesel. Any chance you can run your motor on diesel and see if you get an increase. I have seen many post of people claiming they saw an increase, but you have a test stand that would prove it or not. Anyway great review and thanks for taking the time to do your videos.
Diesel will end up being more fuel efficient as it has more omffff. a turbine running at 115K rpm has the same amount of push no matter what fuel it runs. So maybe initially you might get a higher rpm but as soon as the ecu calibrates itself and limits it to it's max rpm again the results are the same.
