RCU Forums - View Single Post - Jeti DS-24
Thread: Jeti DS-24
Old 02-16-2021 | 07:07 AM
  #1905
digitech
My Feedback: (10)
Originally Posted by jvaliensi
"you connected a extra lead between channel 4 from the cortex to a free port on the cb? , since you cant use anything else then a receiver on a CB rx port"
Nope. The CortexPro had the two receivers in ports A&B and ports 5&6 went to the CB200. This is the standard setup as instructed by BD.
"What software version was your Cortex Pro at and were both RX's connected to the CB200 via the Cortex?"
I updated all devices to the latest firmware as of January 2021.
Thanks for your thoughts.
from the manual :
Note for Jeti connection: For Jeti integration and telemetry feedback from a suitable distribution box through the CORTEXpro (e.g. Jeti CentralBox, Emcotec DUPLEX-Edition, etc.), the EX-bus protocol must be used! The primary receiver must be connected to port B on the CORTEXpro, the secondary receiver to port A. Then connect output 6 to CB‘s Rx1 port, output 5 to Rx2. In addition, route a standard patch cable (signal line can stay) from any CB servo output port to port 4 on the CORTEXpro.
