RCU Forums - View Single Post - Jeti DS-24
Thread: Jeti DS-24
Old 02-17-2021 | 07:25 AM
  #1928
JSF-TC's Avatar
JSF-TC
I've never had a problem with either CB200 or CB400 up until now. No issues with the CB400 in my Hawker Hunter.
I only said it was PARTLY responsible, but in retrospect, why would you put a fuse on a primary flight control - if it trips you guarantee loss of control.
See the current draw profile from telemetry below;
The servo torque was well in excess of design guidelines for the surface.
Nearly 9A just before impact, while most of the flight it was 1-3A. Full flaps and the deflection of the unique tailplane flap configuration likely caused an increased elevator servo draw (MKS 777A+ - 500oz.in/ 36kg.cm) and the inability to pull out of a steepening dive just made it worse.
Going to use a MKS X8 HBL3850 servo with over 700oz.in (50kg.cm) on the elevator for next build also.
Paul
