Any of the pusher jets like these wether turbine fan prop will pitch nose as throttle increases so down thrust is proportional to how high off the wing centerline powerplant centerline is located. Then CG and powerplant HP factor in to degrees. Not really a function of stab heat.
Ill get a pic at lunch been to long but BVM will have the solution pre engineered in OEM assembly pieces if everything is OEM.
