Cortex Pro problem
Hi
I recently bought a Cortex Pro from someone I know, one of the limited edition red versions and put it in my T One Fortune which has been flown many times and is all trimmed out , using the serial port with Sbus.
Everything went well with the calibration but then I noticed my rudder was about 5 degrees out of trim, so I recalibrated it ,same result! I put the tail plane on and each elevator was the same about 5 degrees out.
I checked that the cortex was up to date and recognising the Futaba 18sz.
After a bit of head scratching I decided to try wiring it up with the cable loom to see if the same happens but no the flying surfaces were all perfectly in trim as I would have expected.
The gyro side is working as it should so the question is have I missed something or does my cortex not recognise the plane trims using the serial port correctly.
Any thoughts or help appreciated.
Rob
