RE: obbico A few engine qeustions...
I use the pinch test for low end only. An easier way to do the high end is to simply have someone hold the plane while you bring it to full throttle. Once you reach max RPM, point the plane straight up. You may get a slight increase in RPM, but you should NOT get any decrease. If you do, it's too lean.
