The only purpose of the verticle one is to keep the tail away from the ground.
Not true. The vertical stab is to help keep the nose pointed forward in FF. This is
if you aren't overriding this tendency with HH. If you're using rate mode or no
gyro at all, the vertical stab causes the effect known as "weather vaning".
