RCU Forums - View Single Post - CARF REBEL 2m
Thread: CARF REBEL 2m
Old 03-04-2021 | 06:53 PM
  #303
BoomerSooner
My Feedback: (80)
Originally Posted by jvaliensi
HI,
Does the same work for the rebel hot? I have the full sized pipe and couldn't figure how to install it.
I had to slightly squeeze the bell mouth to get it to fit between the turbine rails to clear the former at the front of the turbine rails. Once it’s clear, you can push it down towards the bottom of the fuse and it will slide back and in to position. You may have to squeeze it slightly again to get it to clear the former at the rear of the turbine rails. Once you do it once it’s pretty easy to get in and out of the fuse.
