For some reason my VSpeak module is not connecting to the Core. It is for the JetsMunts 166 turbine.
Here is my set up. (please see picture)
Two PBR 26 channel receivers going into Powerbox Pioneer
Receiver one is first going into PBS Dock and then into the RX1 port in the Pioneer. The V Speak module is also hooked up to the PBS Dock.
Receiver 2 is hooked up to RX2 port
When I power up the system, the V speak module flashes both the green and blue LED's. (per the instructions this is normal)
I rescan for sensors with the radio using either the receiver or the Pioneer but no luck. Is there a procedure for rescanning for the sensor that I'm missing?
Any ideas? Thanks again
