Originally Posted by
Frank Alvarez
Hello gentlemen,
For those of you using the 2nd Gen Top RC gear controller, have you found a solution to the brake- on/off command?
I have been adjusting the transmitter ATV for the brake command channel to soften the aggressive ‘near-lock’ command.
Has anyone used and alternative solution while retaining the Top RC controller?
Thanks ,
Franko
if you want proportional braking / abs i recommend the Zavionix brake controller
