Originally Posted by
mrjamesdawg
Nope..I hung it back up for now..I contacted vvrc and they sent me an email stating there were no moving parts in an ignition after I told them the problem with noise coming from the ignition and making my whole plane jitter...it might have been funny on there end but I almost lost a brand new plane..it just got worse and worse..at first was a jitter on maiden..a couple of unwanted loops and I shut it off and landed..after that it's so bad it shuts the whole plane off..
Reading through this thread I can see where VV could have mis-interpreted your description of the ignition problem. You consistently refer to "noise from the ignition" but you never refer to it being RFI / electronic noise rather than a mechanical noise. They probably thought you were talking about a mechanical noise of some sort and that's why you got the response you did that referred to mechanical parts. I can understand why you got the response you did. Tom at VV is very good about taking care of customers. You might consider contacting them again with a detailed description of your problem. I'm sure they will resolve your problem. And, I have no connection with VV other than being a customer. They have resolved warranty issues for me twice and without question.
I am a bit curious why the new RCexl ignition didn't work on the engine. Your description of how it runs suggests low supply voltage. What battery / voltage were you using?
