RCU Forums - View Single Post - a good taildragger trainer??
Old 11-10-2003 | 07:35 PM
rctrax
Default RE: a good taildragger trainer??
I don't think a cub is all that great as a trainer. It is a mite sqirrelly and sensetive.The regular trainers such as tower trainer, the pt's by great plains etc, are better suited for getting back into the swing of things. Also Gus is right by the time you add up all the assesorys and materials you need to complete a kit it adds up to about the same if not more. The only advantage to building a kit is it gives you more insight to how it all works and makes you better able to cope with repairs later on if the need arises. Also it gives you the oppertunity to build a better built airplane.You can use the covering and hardware of your choice rather than putting up with whatever is supplied.
