RCU Forums - View Single Post - Tank Unresponsive
Old 03-28-2021 | 01:14 PM
LasvoochTheTiger1Ace's Avatar
Hey guys it has been a while. I decided to just take a morning to just go over all my tank again. And low and behold you would not believe what I found. All the wires attached to the volume knob had been pulled off but since my gearbox helps to hold them in place, I did not notice it. That also explains why the tank would run and then disconnect, due to the wire making contact then disconnecting, then reconnecting and so on. So after resoldering the wires, I tried the tank again and it worked flawlessly! And then my NiMh battery decided to stop holding its charge. Literally, it just reached the end of its life on the next run. Kinda sucks but at least I know my tanks works!
