Originally Posted by
tiger rampage
Alright I received the Rx-18 today and installed it. The functions in the lower hull are all working properly but unfortunately nothing is working in the upper hull. The machine gun and headlight only come on when I push the joystick to the right. Looks like matorro wired the upper hull completely different then heng long did. I will have to rewire it and connect the wires directly to each other. My question is what gauge wire does the heng long rx-18 use? I'm a little new at this so sorry for all the questions. Thank you John
Hey there. Did you ever sort things out with upgrading the Matorro King Tiger with the RX18 or 2.4ghz? If so, can you share your steps? I have an old RX18 board (pulled from HL Tiger, but maybe its not working as expected), but it won't turn the front gears at all, makes some noise on speaker ,but that's it. Haven't tried the upper hull yet with wiring. I get sound, guns and cannon, but thats all connected to board. Was hoping the gearing would work too.
