RCU Forums - View Single Post - Motor trouble
Thread: Motor trouble
Old 04-12-2021 | 06:36 AM
Retiredat38
Banned
Originally Posted by Beaststyle536
Ok, so the motor problem was fixed by a quick esc calibration. The motor recommends 5 to 6 inch props and came with 2x 6x3 props and that is whats on it. How should i test it if it wont liftoff by itself? Should i buy this kit and build it with my parts? It recommends a 2300kv motor and i have a 2280kv.
Never mind, i cannot post urls. It is a FliteTest mini Corsair electric airplane kit. Go to the fliteTest store and go to airplanes then DIY airplanes then Mini. it was the first model shown for me
You mean this one? Mini Corsair
Specifications:
Weight: 270 grams (Fully assembled; without battery)
Wingspan: 29 Inches (737 mm)
Center of Gravity: 1.75 Inches (44mm) from the leading edge of wing (Recommended)
Control Surface Throws: 12 Degrees
Expo Suggestions: 30%
Kit Includes:
  • Laser-cut Foam Airframe
  • 16" Pushrods
  • Control horns
  • Plywood Firewall
  • Corsair Decal Pack
Recommended battery is a 3s LiPo Battery 75C (11.1V/850mAh) and motor is a 2205 2300kV.
If that is indeed the one and if this is indeed your first RC Airplane Model. Then this is NOT the one to start with.
