RCU Forums - View Single Post - To tap or not to tap
Old 11-10-2003 | 09:08 PM
Luftman's Avatar
Luftman
Default RE: To tap or not to tap
Maxtenet
Did you do anything to the muffler with the hole in it (i.e. patch)? Is it ok to run with the hole if you dont need it (how messy)?
Dieseldan
How do you like that twin needle, and how did you do it (does the mvvs bolt/screw right on/ any tapping needed)? Does it really help transition or what?
Anyone,
What do you do with the extra vent line/tap line comming from the tank if not connected to the tap nipple?
Thanks all!
