RCU Forums - View Single Post - Elevator sliding trim not working
Old 04-22-2021 | 04:44 PM
pancake
Default Fixed sliding trim vanguard infinity
Sliding trim pot was working but there was some kind of green glue that the plastic trim wheel and the brass pot stem had deteriorated. I cleaned that out , was able to slide the wheel back a little , then injected a little hot glue into the shaft of the pot and onto the wheel. Pressed it all back together quickly to dry. Worked good as new. Make sure the pot switch it level, compare it to a good pot for approximate angle on the switch.
