RE: gas fuel with glo plug no ignition
You say 50:50 oil ratio, do you mean 50 to 1 gas to oil or 1 to 1 gas to oil?
If it is 1 to 1 that is way to much oil. 50 to 1 is good.
What glow plug are you using, is there a hotter one? Is the adapter getting the plug into the engine as far as the spark plug went?
Could you use a on board glow driver with a small, light weight battery that only is on at full throttle?
