CARDEN EXTRA PRO 300 with KingTech 100TP for power and a dual smoke system,
see
I replaced the batteries last year, and this plane has never been crashed or damaged in any way. It will perform any maneuver your thumbs can do!. It takes off and lands like a dream esp with the inner ailerons set as flaps ( see video) .
WHAT IS INSTALLED:
KT100TP,ECU AND BATTERY, MAIN FUEL TANK, SMOKE TANK, SMOKE PUMP, ALL SERVOS, FUTABA 14 CH RECIEVER, IGYRO, POWERBOX & 2 RX BATTERIES, CF 3 BLADED PROPELLOR, WING BAGS FOR THE MAIN WINGS
Length=112"
WS=125"
NOTES: if you want the DELAWAREJETFACTORY logo removed I can do that. I also will ship the TP manual and original shipping container. The CG as is is perfect there is NO need to change it unless you want more elev authority but I advise against that.
I can travel up to 100 miles from Wilmington De. to deliver, you will need a trailer or large truck to carry this plane
If you will use a Futaba transmitter I can include an SD card with the full program on it. Otherwise I can produce a word document with each servo function by channel# and the throw %. AS mentioned programming is easy except for the program that allows the inner flaps to act as ailerons while still maintaining aileron function ( actually easy with Futaba) You can fly the plane without this feature but it is harder to land as when you try to "flare" it ..it tends to want to climb back up! lol
Shipping will add at least $100 in wood just for the 2 large containers that will be required.
Asking $3500
contact me here or at 302-354-4719 or here on FB or at
[email protected]
