Originally Posted by
Hydro Junkie
DON'T USE EXPANDING FOAM UNDER ANY CIRCUMSTANCES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Expanding foam will continue expanding every time it gets warm and will, eventually, blow the boat apart. I would get some of the blue insulation foam, cut it into blocks and drop it in between the frames.
It's specific boat building foam, closed cell etc, the same stuff that Scott Myers uses.
Hydro Junkie
Now, for your other things you received:
- The rudder bracket could be an issue, due to it's length. It will make the boat act like it's longer than it really is
- Servo mount would be fine if you install it under the cowl and point the arm down. What servo are you going to use for the rudder?
- Do you really need that big of motor? That looks like one that would be used in an electric 1/8th scale
Yeah I just realised they sent me the wrong rudder so it'll have to go back.
This is the servo:
Yes it's big enough to run a 1/8th, might have to build one after this
This is what he suggested so I just went with it. Hopefully not overpowered but I could dial it back with the ESC?
