RCU Forums - View Single Post - Spark plug problems
Old 05-11-2021 | 10:08 PM
PiccoLino
My engine doesn't have much of compression, judging by the force required to flip the prop. Therefore I will try regular gasoline instead of premium and check the ignition timing by the way you say. Then I will let you know if my "spark plug eater" had enough. CK1, thanks again.
