I attached a file that lists what I used initially to set the the LGC15 initially in my Ultra Flash. Once I got out to the field I did some minor tweaking. But this setup worked just fine.
You may want to consider resetting it and starting from scratch. Your gains and nose wheel directions could be different.
I think I wound up with it set to proportional. I will check that tomorrow at the field and get back to you.
Also attached are the final setting for my T-1
