Unusual Frankenstein questions
Hay. So I have a few questions. (Not sure if I am posting this right so bear with please)
questions,
1: what does each wire control on a 5 wire esc that goes to the steering servo. And what wire does what on the 5 wire servo?
1b: is it possible to wire a 2 wire servo into a 5 wire esc?
2: If I use a 60a esc on a toy grade rc car will it blow any thing up? ( I think I know the answer, but just curious if anyone has theories,) I had to use two remotes for it to work which is the reason for the 1b question.
I had to use two remotes cause the esc has a 5 wire servo connection. So I had to use the 60a esc to power the motor and the other remote to turn it. Weird but it works. Hence Frankenstein's rc. Lol.
3: last question..I have a 60a esc in my Hosim 9125 dual brushed motor with oil shocks. Fairly stock. Any suggestions on a possibly larger 2s lipo to run other than stock, (7.4v 1600mah 25c) can I use a 3s?
