RCU Forums - View Single Post - If you are new to RCU--READ THIS FIRST!!!
Old 11-11-2003 | 06:47 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: If you are new to RCU--READ THIS FIRST!!!
ORIGINAL: robgusto
This is the beginner forum is it not? That's why I came here to ask my novice questions. If you don't want to help then don't reply!!!!!
You are right, and all questions deserve a good answer. This is one reason why we do things like post FAQ's and write "How To" columns in the RCU Magazine.
Here's a typical analogy: A beginner asks a simple question that requires a detailed answer. Then someone takes the time to give a detailed answer.
A week later, someone else askes the same question. And gets a good answer.
A week later, someone else askes the same question. And gets a shorter answer.
A week later, someone else askes the same question. And gets an even shorter answer.
A week later, someone else askes the same question. And gets a bad answer because people are tired of answering the same question over and over.
I have seen this first hand, and every time I see it happening again, I get a new subject for a "How To" column.
Check the RCU Magazine, and select "How To's". There's tons of good info there.
